Is there a way to automatically reboot the device once a week?
Hi pbjarvis2000:
Thank you for the inquiry. You can setup a reboot schedule from the support.cgi page of the MAX on a daily or weekly timestamp (see screenshot).
To get to the support.cgi page, login your Web Admin Interface as an administrator and type the following on your web browser, replacing the “IP of your device” field with your device’s web admin access IP address. By default, it is set as 192.168.1.1:
http:// IP of your device /cgi-bin/MANGA/support.cgi
I hope this helps to clarify things!
Thanks that worked
