We just migrated two more installations FROM that manufacturer to Peplink. Primary reason: Lack of support from the manufacturer. If an authoritative response in a day or two from one of Peplink’s most helpful engineers, @TK_Liew, wasn’t sufficient, well … let us know how the Unifi stuff work for you! :<)
i turned on “fast transition” after i found the setting. after a few resets of the AP, they seem to be behaving. I put my fixed devices (IoT devices on a dedicated SSID and put my iOS “fast transition” on a dedicated SSID… for now, things are working well.
Seems like enabling “fast transition” helped. I noticed there is no “fast transition” option without using my balance router (was also experimenting with a non-PL router to do some ipv6 stuff)
question, is there a way to enable fast transition without a balance router AP controller?
