We’re happy to announce that the AP One Firmware 3.6.1 Beta 1 is now available.
“20046 - Added the ability to turn off the green Status LED on the AP One Enterprise”
Thank You!
Tried it on a “Mini” – 'Invalid firmware pack." What did we do wrong?
Does this version also incorporate the speed issue correction from 3.6.0s18?
Hello Peplink Team,
Have we any news on updates for the Pepwave AP Pro series?
Product Code | Product Name | Description |
APP-AGN | AP Pro 300M | Industrial-grade 802.11 a/b/g/n 300 Mbps access point in metallic waterproof and dust-tight IP67 outdoor enclosure. |
APP-AGN2 | AP Pro Duo | Industrial-grade 802.11 a/b/g/n 600 Mbps simultaneous 2.4 & 5 GHz access point in metallic waterproof and dust-tight IP67 outdoor enclosure. |
APP-AGN3 | AP Pro AC | Industrial-grade 802.11 a/b/g/n/ac 1750 Mbps simultaneous 2.4 & 5 GHz access point in metallic waterproof and dust-tight IP67 outdoor enclosure. |
https://www.peplink.com/products/industrial-grade-access-point/pepwave-ap-pro-ac/ |
We’ve not seen any firmware updates to this series for a long time.
AP One/AP Pro
Product | Hardware Revision | Firmware Version | Download Link | Release Notes | User Manual |
AP Pro | HW1 | 3.5.4 | Download | ||
AP Pro Duo | HW1 | 3.5.4 | Download | ||
AP Pro AC | HW1 | 3.6.0 | Download |
Showing 1 to 3 of 3 entries (filtered from 12 total entries)
This series is sitting at 3.5.4 released over three years ago (12 May 2016).
Happy to Help,
Marcus
Hi Rick,
Firmware Pack is a special package that is to be loaded on AP Controller. The released firmware is a firmware image to be loaded on AP instead. If you would like to try the beta, please make sure the firmware assignment has been disabled (Under Controller Status → Access Point, select the corresponding APs, click “Set Firmware Pack” and select “None”), then load the firmware on each APs through the WEB UI of the APs.
Gary
OK. 'Firmware Pack" vs “released firmware.” I get it – I think.
