amospo
April 23, 2018, 11:44pm
1
Hello i have brmax in the field i need to transfer voice ppt to center to roip server that make multicast
can i use with peplink380 in the center and br1 in the car
if i operate speedfusion in br1 ?
to 380 ?
You need to setup Layer SpeedFusion to forward the multicast tracffic between BR1 and Balance 380.
Introduction
Since Firmware 6.2, we have redesigned the Layer 2 PepVPN feature. It is now easier to use and more flexible, allowing it to fit into more use cases.
However, to achieve this, the new Layer 2 PepVPN feature is not compatible with existing Layer 2 PepVPN profiles created using firmware 6.1 or below. After upgrading to Firmware 6.2, all existing Layer 2 PepVPN profiles will become normal Layer 3 profiles. In order to reconfigure them back into Layer 2 profiles, please follow these ste…
