Is there a way to disable the green light on the AP One Enterprise? I have looked through the settings and do not see it. Thanks.
The LED status light indicates your device’s status. RED – Access point initializing
GREEN – Access point ready. Any reason why you need to disable it?
Hello Chun, @Chun_Fatt_Sham
I believe that @FrequentFlyer is referring to actually turning the LED indicator off, this is a feature found in many other manufactures equipment, it is supplied for those that are energy concerned or do not want to draw attention to the equipment.
Happy to Help,
Marcus
Chun,
I have an AP One Enterprise mounted in a location where complete darkness has been requested as an option. Some equipment (Sonos comes to mind) has an option on each unit to enable/disable the light.
Marcus,
Yes, I am asking if there is a way to completely turn off the LED indicator (or at least turn it off when it would otherwise be green).
Thanks.
You can stick a label on it
Good News guys!
Disable light is possible in this release!
