we are doing some testing with a balance 580 and HD2 Max Mini’s. We are simulating a remote office that’s connected to our datacenter through a speedfusion tunnel. So we’ve configured a speedfusion tunnel between the devices and ran bgp over it. There’s iBGP between the local network and the peplink device and eBGP over the Speedfusion tunnel. Except for the 0.0.0.0/0 route that I have to configure manually - because it’s not supported yet in firmware version 7.1.1 - most works fine.
So here’s what I’ve encountered now: the central side learns the routes from the remote office fine. The problem is that it learns the routes through the actual nexthop address (=the IP of the speedfusion tunnel), which is not known by the central network. So the central network forwards this traffic to its 0.0.0.0/0 address, where it gets dropped because it’s an unknown network.
So my question is: is there some way that we can advertise the remote subnets to the central side with next-hop-self ip address? In other words, is it possible to advertise to the central side with next hop address being the ip of the interface of the balance that’s connected to the central side?
Thanks!
Hi Bramdh,
I know you asked this question a while ago, but I came across this post and thought you’d like to know that BGP next-hop-self is supported in firmware 8.0
Erik,
Yes we developed this together with Kenny. Bram helped with a lot of useful elements on BGP.
Guaranteed tested and working
Again a quick and good job from Peplink dev team
Kr,
