Zerotier Static IP Starlink
Hi, How do I set a static IP port forward with my two Starlinks (RV ROAMING) bonded on SFC? I know Starlink business offers static IP but not residential.
I want to remotely send SRT from our LiveU streaming encoders to our OB truck.
Any help would be appreciated. Thx
Hi Mark, you can’t, you need a hosted FusionHub to support inbound port forwarding.
That way you get your own dedicated public IP in the cloud and can forward what you need to where you need it to go.
Thanks Martin, I’ll look into fusion hub
Hi, @markhepi
Please… look at this url…
The guy has the same issue as you and was solved, using FusionHub at cloud.
