I grabbed the BR1 device data with snmpwalk, but when I wrote it to zabbix, I reported an error.
snmpwalk -v 2c -c public 10.x.x.x ifDescr
IF-MIB::ifDescr.1 = STRING: LAN
IF-MIB::ifDescr.2 = STRING: WAN 1
IF-MIB::ifDescr.3 = STRING: WAN 2
IF-MIB::ifDescr.5 = STRING: Cellular 1
IF-MIB::ifDescr.6 = STRING: Cellular 2
IF-MIB::ifDescr.7 = STRING:
How do you solve this problem,Please help me,thank you
Please perform packet capture from the BR1 device and verify the SNMP sent from the server to the BR1. Make sure the SNMP request is able to reach to the BR1 device.
Please start the investigation using a MIB Browser to make sure OID defined is correct.
We use zabbix to monitor our BR1s and FusionHub. What I have noticed it that we had to uncheck the “Use bulk requests” box while configuring the host interfaces for BR1s.
Can you please confirm when you enable “Use bulk requests” what are the SNMP requests will be send from your server ? We are not Zabbix support hence we need you to provide more info in-order for us to investigate the issue ?
I tested some OID information, but found that the bandwidth traffic obtained is not very accurate. Can you tell me which is the correct OID information for import and export traffic?
