Dear All
I just see your product “Pepwave MAX On-The-Go MAX-OTG-U1, HD29974. Single-USB 4G LTE / 3G router”
also i see that there is solution for TV broadcasting. i need to know if that you have complete solution of transfer on air video streaming directly to the channel like as example TVU ? if that i need to know more about this solution
also want to ask if that there is any other model that could me connect more than 4 usb modem??
Regards
You can refer the following URL for details. Both MAX 700 and OTG supports up to 4 USB modems.
You can use your own application on top of SpeedFusion Bonding.
