hi - I want to connect my Primecare Pepwave Max Transit Duo router to the 12V battery in my RV but I can’t find any instructions on how to wire it properly using the connector that came with the router. Perhaps I missed the instructions but I looked in the manual and could not find anything. Can someone provide me to those instructions?
One other question, there is an existing 12V wire going into the RV sound system that I will patch into so the single 12V wire coming from the battery will power both the radio and my router. Any issues you see in doing that?
Be advised that your router will run hotter if you use the terminal block. Depending on the voltage input to the router, it will dissipate excess voltage (step down) as heat - no harm to the router, but check the surroundings for heat issues.
