I’m using 10 max br1 routers. All are fine except 3. Problem is they are not accesible by my devices. I use raspberry pi . i cant see peplink router in SSID scan. So i was trying to narrow down this issue from router issue. then i found wifi wan is not able to scan even half of the SSIDs my raspberri pi scaning.
Does it mean that particular router’s wifi is so weak which is why my devices can’t reach it ?
is it harware problem ? other peplinks can scan 10-15 ssids but these 3 show only 1 or 2 that’sall
