I have a PEPWAVE MAX_BR1_1C4C router.
I use this router to manage a LAN Wi-Fi network.
Into this network, a device (IP: 192.109.211.151) sends an broadcast UDP message at 0.185 second rate on the port 25000.
I observe this message with WireShark software and I notice that the message hasn’t a 0.185 second rate all the time.
At the beginning it’s correct and after about 80 messages it’s shifted to 0.3 second rate (see the attached file and the print under).
It’s just a broadcast service and the 0.185 sec rate is to have a fluid display.
Anyway, the 0.185 second rate don’t always change after 80 packets. It could change at any time.
The wired connection has not the same behavior and it works perfectly. The 0.185 sec rate is constantly maintained.
Can I send myPEPWAVE MAX_BR1configuration?
May i know the WireShark packet captured result that you shared previously are from which device ? Beside that, possible to share us to software name that sending the UDP broadcast ?
Please find a network schematic showing the different hardware.
I don’t think it’s a problem with the Ti OMAP137 hardware, because it perfectly works in wired connection with the PepWave router.
I think it a problem of Wifi router configuration.
It’s common that for WIFI connection network packet sent slightly delayed due to the WIFI medium used. It’s influenced by the WIFI signal & interference for the environmental.
Recommended, multicast or uni-cast traffics is used to improve the performance.
This is not related to the AP configuration and it’s more on the latency causes when travelling using WIFI medium compare to Wired. If you need such high guarantee round trip time (0.185), please consider to use wired connection.
