For some reason my wifi SSID is not visible.
I have a Br1 Max 5g at firmware 8.4.1.
I have pretty nice/standard wifi antennas on it.
In Web Admin, I enabled the AP controller and setup a SSID. I made sure the SSID was broadcasting and visible.
I forgot that I could control this from Incontrol2 as well. So I went there and get all the devices the same SSID and made sure it was visible there.
I still don’t see the SSID visible on my phones or laptops.
Any idea what could be causing this?
It’s just a standard WPA2 network… Nothing special…
EDIT: I should mention that I currently have no external APs on. I’m trying to get it working with just the Max’s builtin Wifi to start out with.
Thanks!
