WiFi Passpoint on access points
maybe it should be posted under feature request.
I’d like to know if you have any plan to implement/support 802.11u authentication or WiFi Passpoint option on your access points? So that EAP-SIM would be feasible option when authentication mobile clients?
Also is there any plan for outdoor 802.11ac access point?
Best regards,
Gregor
@ProjektIP I’ve moved this to Feature Request section.
Hotspot 2.0 is something to look forward to, but I’m afraid it’s not an immediate plan atm.
As for outdoor access point ac, you can take a look at our AP One Flex, which comes with ac and IP55 rating.
Any update on passpoint hotspot 2.0? Curious as it’s been about 9 years since this feature request.
With starlink minis and peplink 5G, this makes a strong passpoint case build for disaster deployments.
