Hi all, would like to find out has anyone have some experience in using these products for wireless cctv platform in buildings? Want to have something reliable so that the cctv feed will be smooth and with no distruption.
Hi yes we do this all the time. Its super reliable and provides very easy remote access for IP CCTV and NVRs.
Hello
I have an IP Cam. With a flat panel WiFi antenna 300 feet away from a surf on-the-go with a flat panel WiFi antenna, and all is great. The surf on-the-go is then hard wired to a surf so-ho mk3. The IP Cam is HD, and live feed and recording work great.
