So, my wife has been complaining about dropped calls and FaceTime. I decided it was most likely her mothers rickety internet. But, then I looked a bit closer and it appears that my traffic shaping may be causing the issue for inbound stuff.
I have two iPhones, two iPads, and a m-cell (voip device for AT&T).
I did a packet capture and saw that there is some kind of TURN protocol and SIP stuff. I am no expert in this area and I know that Peplink does some stuff under the hood with regards to SIP and ALG and UDP 4500.
I have a feeling that the iDevices are doing some sort of registration through some kind of web service URI or URL. I think this is where my issue lies. I try to maximize my links and try to “balance” as much as I can. Outbound TCP 80 and 443 are done in a round robin fashion. I think the devices are using these ports to register, so inbound traffic is going to come in to a seemingly random WAN. But then I have outbound policies to keep UDP 4500 onto my WAN that supports VOIP. Technically, both should - but one is much more reliable for real time traffic.
Has anyone figured out how to set this up without having to restrict all traffic from a particular device to a specific WAN.
I am thinking of doing a test where I start the packet capture, then turn the phone on and monitor all the traffic. I bet I find a web request to something like wificalling.apple.com or similar. I just restrict that traffic to the WAN I want and all inbound calls should come in on the correct WAN.
Please don’t ask me to open a support ticket. This is a configuration issue that several can benefit from. It is specific to a multi-wan environment. Has anyone already sorted through this one? Is there some other magic going on?
