Hello @Paul_Y,
Start with a Pepwave MAX Transit model or Pepwave MAX HD# MBX model, then pick a Peplink router to give you more WANs to use for Wi-Fi WAN and add in the Pepwave Device Connector.
It all comes down to costs. If your budget is small, consider a MAX Transit on PrimeCare and use its two Wi-Fi radios. If budget is not the issue, go with a MAX HD2 MBX with additional Pepwave Device Connectors on its WAN ports.
Both recommended routers have Celluar modems within, though there are many ways to build this solution for you.
Note that the Pepwave Device Connector is not approved in all areas worldwide.
Your local Peplink Partner can assist in getting the solution together for you.
