Hi, is there any Pepwave product that combines the functions of:
- Wifi AP
- Wifi client
- Bridge
and can be switched among them by configuration?
The short answer is “yes.” E.g., the BR1 family of routers. Have a look at the spec. page and the rows labeled “Wi-F AP”, “Wi-Fi WAN” and “IP Passthrough” respectively.
Z.
you can also consider device connector ![]()
Thanks for the information. I understand that Device Connector can only function as Wifi client and bridge only but not Wifi AP?
Basically you need Wifi repeater. Device Connector meets your requirement.
