I have a max br1 5g and I am struggling to understand the algorithm used in the pepwave.
say I have cellular connected along with 2.4ghz and 5ghz WiFi. how does the pepwave choose the Path to the internet?
dows it find the fastest path, pick one at random, or one with the lowest ping, or ???
any input is appreciated
It’s what you set it to. Read up on all the algorithms
Where can I read up on the algorithm? I’ve searched and couldn’t find any explanation
Go look under Outbound Policy on your router and in the user manual. The default is set to Auto which uses the Lowest Latency link. But there are many other algorithms available.
