Pepwave MAX HD2 firmware 7.1.0 build 3433 (same issue on firmware 7.0.1 build 2988)
When trying to setup a Wi-Fi WAN connection the device scans for networks constantly but none ever appear in the Wireless Networks pop up window and the Wi-Fi Connection Profile I manually created never connects either.
All antennas are connected to the Pepwave including the 2 WAN antennas in the front of the device.
My phone and laptop both show a number of available SSID’s and can successfully connect to the Wi-Fi network I manually entered into the Pepwave (the one I want to use as Wi-Fi WAN).
The Pepwave is able to generate a Wi-Fi network of its own. The Pepwave also has a wired WAN connection and a 4G cellular connection.
Other interesting behavior: If I drag the Wi-Fi WAN connection down to “Disabled” or a lower priority, it pops back up to Priority 1 after a few seconds and continues “Scanning…” This behavior is happening in Chrome, Firefox, Edge and IE.
The second issue of not being able to disable or change priority for the WiFi-as-WAN connection is actually a bug. IN AP/AP mode WiFi-as-WAN connection should be disabled.
Our developers will implement a solution in the next firmware…
Are you planning on using WiFi-as-WAN? If so please change the AP settings to WAN /AP mode.
