ISSUE = Majority of Wi-fi clients will not join SSID#2 on two of the six Peplink AP’s.
However, all Wi-Fi clients can join:
- SSID#1 (on all the APs).
- SSID#2 on four of the six APs.
PEPLINK SYSTEM (All @ latest Firmware)
1) ROUTER = MAX BR2 PRO 5G (MAX-BR2-PRO-5GH-T-PRM HW V4)
SSID #1 = DEFAULT VLAN
SSID #2 = VLAN 90
2) ROOT SWITCH = Peplink SD Switch 24-Port (PSW-24-850W HW V2)
3) SWITCH #2 = Peplink SD Switch 8-Port Rugged (PSW-8-240W-RUG HW V1)
4) AP’S =
AP #1 = ROUTER BUILT IN AP
AP #2, #3, #4, #5 = AP ONE AX (APO-AX HW V1)
AP #6 = Peplink AP One Enterprise (APO-ENT HW V2)
Problematic “APO-AX #4” =connected to Port 5 on PEPLINK 24 port switch #4
Problematic “APO-AX #5” =connected to Port on PEPLINK 8 port switch2 #1
Note - all AP’s are connected to PEPLINK 24 port switch w/POE except AP#5. All switch port programming has been confirmed good.
NOTES
I was able to get one ipad to connect to SSID#2 on both of the problematic AP’s
FACTORY RESETS PERFORMED on all peplink devices last week.
All FW is up to date on all peplink devices.
PEPLINK WIFI NETWORK CONFIG SUMMARY
TWO STARLINK WAN CONNECTIONS
TWO SSID’S:
SSID #1 (DEFAULT VLAN) assigned to Starlink #1
(Router / Firewall / OUTBOUND POLICY, ENFORCE NETWORK TO WAN1) -
SSID #2 (VLAN 90 assigned to Starlink #2
(Router / Firewall / OUTBOUND POLICY, ENFORCE NETWORK TO WAN2)
TIA
