Wi-Fi and WAN settings
When I setup a Wi-Fi wan the SSID shows up in the AP and I can’t change it. If I kill the WAN I can change the AP but it changes back when I connect to the WAN WI-FI. I am sure I am doing something wrong but can’t for the life of me find it
Hi Try to set up one wan on 2.4 or 2nd wifi on 5g or other site
Hey,
Take a look at your Wi-Fi connection profiles that are found under your Wi-Fi WAN interface in the dashboard. If you have multiple profiles, the Wi-Fi WAN interface should try to connect to them from top to bottom. You can also specify if the device should automatically connect to a profile when Wi-Fi WAN is enabled or not.
Does that help or is the issue different?
Best Regards,
Aivaras
