Anyone have a clue on this one?
From the screenshot, a PC inside your LAN (192.168.50.24) is trying to access to remote web server (52.18.38.89) on port tcp/80. This is a web traffic. Your outbound firewall access rule is blocking this traffic. IP address 52.18.38.89 is belonging to Amazon.
Do you want to block this traffic ? It this your requirement ?
Thank You for the response
I have blocked it. I just don’t understand why a IP from Ireland is doing this. It just started.
The “source” is the PC inside your LAN (192.168.50.24) initiating these sessions, not an IP from Ireland. This is seen in the event log as your “outbound” firewall rule is blocking this traffic from 192.168.50.24 on the LAN.
Thank You for the reply
I’m trying to figure out what’s doing this. It’s from my MacBook Pro.
Found it.
It’s from the Ivideon app. From a security cam. That I use.
It never did this before.
