Trying to figure out which router will run 5G, LTE, 4G and 3G to put inside my grand design momentum fifth wheel trailer that we use a couple times a month. I have already purchased an AT&T Sim card, nano size, along with a data package.
Hi @Rodney_Vance. You may compare the various MAX products using the tool Peplink thoughtfully provided. My bias these days is probably in the direction of the MAX Pro 5G or, if you need to save a few bucks, perhaps the CAT 20 version. These products were recently reduced significantly in price – nice! But there (You mention 3G – it’s gone. 4G is “here” and 5G is “sorta here” – depends where you are.)
I’ve sent you a PM.
Rick
