Hi
For a 3 level house of approx 2,500 sqft with plaster walls, which one would you recommend for best signal and fast speeds:
2 x AP One AC mini
2 x AP One
Hi
2 x AP One AC mini
2 x AP One
Which other AP One are you looking at?
These are the AP One option
AP One AC Mini
AP One 300M
AP One In-Wall
Speed
All are 300Mbps at 2.4GHz and 5GHz excpet the AP One AC Mini which is rated at 866Mbps in the 5GHz frequency
Coverage (With line of sight in open environments)
AP One AC Mini 400ft/122m
AP One 300M 750ft/228m
AP One In-Wall 400ft/122m
The best one for you would be the AP One 300M
Hope this helps
Wouldn’t the mini one provide better speeds? Most devices connected will be Apple.
The AP One AC Mini will only provide better speeds then the others on 5GHz. At 2.4GHz its the same as the other models
I currently have an AP One AC Mini in my 2000 sqft 3 level split - it works excellent. I placed it in the attic above the 2nd level. I have solid coverage everywhere in my home. A few notes on the differences between the AP One AC Mini and AP One 300m:
If you really wanted to max out throughput in your home, using two AC mini’s on opposing sides of the house would really work nice, but you may be just fine with one located centrally. My home is pretty standard US construction (2x4 frame with 3/8" sheetrock), plaster and other materials will certainly reduce your range/throughput.
Thank you Travis and Gno, that helps a lot.
