I can’t test SNMP v1/2 on the device Balance 580 (updated 6.2.2) but V3.
I only find MIB file v1/2, please let me know where can I download MIB files for v3?
Or if you guys have any solution to test SNMP v1/2 correctly, please advise me.
I need some mib files as below:
HOST-RESOURCES-MIB
hrMemorySize - .1.3.6.1.2.1.25.2.2
hrStorageTable - .1.3.6.1.2.1.25.2.3
CPU
UCD-SNMP-MIB
System Stat .1.3.6.1.4.1.2021.11
If you have mib files support v3, please kindly send me the links to download.
Content under the line you marked red color is the text lines I need to add in DEVICE.mib file right?
I checked the DEVICE.mib file downloaded on this link: http://www.peplink.com/support/downloads/software-supplements/
(Peplink Balance SNMP Private MIB for 6.1 or above (Updated at Apr 22, 2015)) but don’t see deviceInfoUsage, only see deviceInfoSystem and deviceInfoTime.
Attached are the 6.3 device MIB files for Balance. Please make sure your device is running using 6.3 RC and you should able to monitor the CPU & memory usage for the device.
For your information, Balance/MAX 6.3 private MIB files will be uploaded to the public download link within this few days.
