Which antenna for outdoor 5G on Balance 310 Fiber?
Hi everyone, I use Rogers 5G in Canada and have a Balance 310 Fiber router. I’m looking to install an outdoor antenna as where the router is indoors has very poor signal. My preference is omni directional vs directional but open to whatever works. There’s several Peplink antennas I see so I was just curious which would be recommended for 5G, and if I only need 1 of them or multiple, as years ago I recall having issues where antennas I’d buy online would only have 1 SMA connector where it should have been 2, (or maybe it was 2 where I needed 4), I can’t recall. Love to get any recommendations on which model would work best. Thank you!
Hi. You want a 4x4 mimo 5G antenna for the 5G modem in your B310.
Two choices from Peplink for omnis, the maritime antenna:
and the Mobility antenna:
From what you have said, the maritime 40G might be a better fit for your needs.
