Where to get replacement access point mounting brackets/plates?
When the Jawas tear out an installation, they tend to leave the little bits behind. I’m wondering where to buy replacements. Also, if any of the Peplink access points use a common bracket design between models. Or if there is even possibly some industry standards at play.
Any suggestions?
Are you looking for a specific bracket/mount for a specific model? I see you mentioned APs, are you looking for brackets for those?
At the moment, I’ve got a few APO-ENT units without brackets. I think I need one for an AP One AX lite as well. I need to check that model number. Do any of the models share brackets?
Hi…
Try this URL
https://estore.peplink.com/categories/accessories?categoryPath=accessories%2Fmount%20kit
I’m not seeing the brackets I want at that link.
The bracket for the AP One AX and AX Lite is ACW-783. Let me know if you’d lke me to help you get them.
I’m looking for AP One Enterprise (APO-ENT) as well.
