I used to find it in the daily chart. I don’t see it anymore.
Apart from that, Good job ! Im’ happy to see at least things we could find easily in WRT open-source firmwares.
Regards
Regards
Hello e-gaulue,
If you are looking for the Bandwidth Usage Charts for the Balance series, on the latest firmware 5.4.9(as of today) they are located by navigating to the “Status” tab then on the left hand side toward the bottom of the web page, you can choose realtime, hourly, daily, or monthly. once you choose that you can look at times. I hope this helps
