Was just curious if anyone else has encountered this as it has only started for me as of a month or two ago from what I can tell. Basically what happens is with any of my devices, if I log into IC2 and then do the “Remote web admin” to access the device remotely, certain changes I do kick me out of the remote web admin and I can’t log back into it for at least 30 minutes.
For example, if I log in and I see WAN1 is up and LTE1 is up, but I manually disable WAN1. The remote web admin stops responding, and if I close the tab and try to access it again, I’m not able to for at least half an hour. It just says contacting device then shows a solid blank white page. Same if I log in and make a change such as to outbound policy and save it, the web admin stops responding and if I try to access it via IC2 it’s just a solid white blank page. Manually rebooting the device doesn’t seem to help, the only thing that seems to work is coming back at least 30 minutes later where it then works again.
It’s a pain as sometimes I’m doing testing and want to disable a WAN temporarily which then kicks me out for awhile. It does this on all our devices, Balance 305, BR1s, HD2s etc. I never used to have this problem but seems to have just started in the past month or two, and does it from Chrome, Safari, Mac, PC, etc.
