Hi ,
I’m the lucky owner of 2 UBR LTE and a Balance 310 5G, what happens with availability of the products ? I’ve checked everywhere in Europ sellers its mainly impossible to buy BR1 HW3 / UBR max or so … Something will happens soon or ? That’s really embarrassing for us actually . BR
There is another post here talking about similar topic.
That’s really a problem , if you’re reseller do you know if that’s the end of peplink ? Do we need to go to another technology or what will happens ?
I need quickly to find more devices there’s no availability anywhere ![]()
As I understand it, Peplink are actually making the product range more streamlined to make stock more available to the channel.
We sell a lot of devices, and some device availability changes have tripped us up recently, but Peplink has worked jard to help us make things right.
Its going to be fine.
The UBR-LTE has been EOL for some time now as the chips used inside it are no longer available from suppliers. Same with some other models.
They are streamlining the amount of products they are offering, as there are just too many models in many verticals, while you could consolidate a lot.
The recent launch of the B One/B One Plus and B One 5G replaces a lot of other models and can fit the needs of many for example.
