If you’re running pepvpn or speedfusion to protect your connection on a balance or pepwave max, would you do anything differently when using an “untrusted” wan connection over your normal ISP connection, e.g. when using a free building or community wifi hotspot as wan?
@aquablue
Make sure encryption is enabled for the tunnels traffics and it’s safe to run on free building or community wifi hotspot as wan.
I treat all WAN connections as untrusted. So I treat them all the same.
