What to replace our Peplink Balance 20 with?
I am using a Peplink Balance 20 running 6.3.2 firmware in a small business environment, the main function of the device is to hook up two ISPs and to have redundancy if one goes down.
We’ve had the device for many years, works as advertised. I am looking to refresh the hardware, basically looking for the ability to connect two ISPs and also have the option for LTE/5G for futureproofing.
Would the Peplink B One 5G be the upgrade path from a Peplink Balance 20?
This is a retail store with about 20 computers, nothing crazy in terms of bandwidth, subscribed to 250/250Mbps on both links.
Also wanted to confirm that IP passthrough (bridge mode) is supported on this one? I have a firewall appliance that I want to act as the default gateway.
Hello @mirza.dedic . The peplink B one 5g would be a great choice as it supports two wired wans, and a cellular 5g.
IP passthru is supported on this.
We are a peplink partner if you want to send us an e-mail to [email protected] we can send you out a quote and support you after the sale with assistance transfering your config from your old balance 20 if you’d lie.
