Is there anything special to pay attention to when buying Peplink Balance 580X or I can’t go wrong?
It runs the same OS and same feature base set as all other peplink routers. When choosing different routers it really comes down to making sure it has the correct number and type of WAN/LAN ports, expansion ports, and either has or is licensable for your required end capacity. Check all those boxes and you can’t go wrong.
