What’s the smallest / cheapest router for SpeedFusion
Hi
I already have a MAX BR2 Pro router. I’d like to set up a SpeedFusion link. Which router model should I choose for the other end? It needs to be the cheapest one.
The B One (not the 5G version) is really good and about the cheapest thing Peplink make.
The AP series can also do Speedfusion, but I’m not sure they’re any cheaper, and a little weird.
And you really ought to consider lifetime cost, not upfront cost if you plan on using any core features of SpeedFusion like hot failover, bonding, or smoothing (because most models require PrimeCare subscription to activate).
In terms of lifetime cost, the B One (not 5G) uses the cheapest PrimeCare+ plan “A”, which is quite a bargain.
What are the costs of purchasing the device and the annual subscription?
I found this here:
Peplink B One | PeplinkWorks.com
I mean it’s on that page, $300 plus $50/year or $60/year with hardware swap and email support.
