I need to declare all the traffic for my LAN. I have an AP one that need to be controlled by Incontrol and Incontrol2 (when available) but I dont know whan port the AP uses to communicate to incontrol. I think is TCP 11753 and UDP 11753, but not sure…
By default Which WAN connection it will use to connect with InControl2, because i need to define allow policy in my firewall based on source IP, which will allow Peplink device to communicate to InControl2 server
I’m afraid to say that we are still in the process of creating a proper mechanism on how Pepwave Access Point (AP) series will access IC2 server. Therefore, we don’t have specific information as of yet. We will keep you updated. Stay tuned.
We use 3 balance 1350 and 3 710 as speedfusion endpoints (fleet of about 30 HD4’s + additional transit and transit duo’s).
While the WAN is connected to the DMZ firewall the balance routers, internet access is handled by
another router/firewall (it’s a huge network and the FW rules have to be administered in a central system), so I made a static route 0.0.0.0/0 to the LAN GW so all client data is trough.
However at this point the incontrol stops working, because the balance routers try to access the incontrol servers trough the LAN and the F/W stops them (only client subnets have outgoing rights,
the balance lan ip’s don’t)
Forcing an outbound rule (forcing traffic to peplink.com to WAN1) didn’t help either.
The quick and only fix was to allow outbound traffic on ports 443/tcp and 5246/udp
for the LAN IP’s
So stating that the peplink devices choose one of the WAN ports is incorrect!
