Might seem like a stupid question, but anyways.
What OS does the max routers run?
AL
AL
Its Linux.
Sorry for bumping an old thread, however it is the first result that came up while researching my device after doing nmap scan. ( and this thread has received 160 views from people, probably similarly looking for a detailed answer. Im sure over half of the 160 viewers had already know linux is default Router OS on most routers )
Can someone point me to a source of information for expected results from a typical:
MAX BRE Model
Pepwave MAX BR1
Product Code
MAX-BR1-LTE-US
Hardware Revision
2
In particular I am verifying (since the product was obtained second hand) the default information displayed.
For firmware 8.0.0 - Which version of linux would be running?
OS CPE: cpe:/o:linux:linux_kernel:..**
OS details: ********** (Linux ..**)
Are these normal port results?
53/udp open domain (unknown banner: Version: recursive-main/22386077)
8008/tcp open http nginx
And who is the certificate authority of the default installed SSL certificate? Is it Comodo? and Previously before I upgraded to firmware 8.0.0 from 6.4.2 it was a GoDaddy certificate.
I believe I have captive portal off but this may just be showing the certificate installed even if its off:
ssl-cert: Subject: commonName=captive-portal.peplink.com
| Subject Alternative Name: DNS:captive-portal.peplink.com, DNS:www.captive-portal.peplink.com
| Issuer: commonName=COMODO RSA Domain Validation Secure Server CA/organizationName=COMODO CA Limited/stateOrProvinceName=Greater Manchester/countryName=GB
| Public Key type: rsa
| Public Key bits: 2048
| Signature Algorithm: sha256WithRSAEncryption
| Not valid before: 2014-11-18T00:00:00
| Not valid after: 2019-11-17T23:59:59
| MD5: 8 groups of 4 symbols
