What is the IP Ratings of MAX indoor series?
For example, I need IP protection rating for MAX-BR1 M2M. Can be IP30?
You should specify it for all models in product matrix.
+1, I would like to know the IP rating of the MAX-HD2 and MAX-HD4.
Hello @aytan34 & @Joey_van_der_Gaag,
There are versions of the Pepwave MAX HD2 & Pepwave MAX HD4 that are IP67 rated (these are special order items).
The rest of the Pepwave MAX range can be treated as IP30 and the Pepwave MAX Transit range as IP40, this is based on how we read the standard and have used the equipment.
As the devices are not sealed against moisture, it is not possible to rate the second digit above zero. If you treat the network cable connectors as a hole, then the IP rating needs to be dropped for the first digit to 2.
That said we have installed the MAX range in some very extreme conditions (dust, humidity, corrosive) and they have been surviving just fine, some products we put inside our own suitable rated & customised enclosures.
Happy to Help,
Marcus
Thank you very much Marcus,
