What is the Best Roof Mount Antenna for the MAX BR1 Mini
I have a roof mount Starlink Flat High Performance Kit. I want to share my internet connection outside the vehicle while driving or stationary. I lack cell service in many of my locations, and my team needs internet for VOIP and navigation. I need a reliable, flush, and waterproof roof mount antenna that maximizes the MAX BR1 Mini’s in- and out speeds. I won’t insert cell cards into the MAX.
Hi, @warnerl
Maybe Mob 02 is an option?
Have you personally used the Mob 2?
Yep…
We have a project called connected backpack.
@MarceloBarros That backpack looks neat!
What does the inside look like? What battery system are you using?
Hi, @MartinLangmaid
Inside of backpack?
Another box… ha ha ha
LTE 4G+ sample box.
We don’t have a fix battery solution for all box models. Because each one have one lte or two lte or three lte devices on it. Some just 4G, some just 4G+, some 4G+ with 5G and other with 5G only.
So… We first check what device will need to be at the box. Ask to customer how many hours he will need and we install a battery and AC circuit to charge it.
