What is a Pre-Activated SIM Card?
#1
A pre-activated SIM Card is one that is already activated on the carrier network. Some of our products require pre-activated SIM card.
  • If it is an existing SIM card that you are using in an USB modem or other device, it is a pre-activated SIM card.
  • If it is a newly issued SIM card, you can activate it simply by inserting it in a device certified by the carrier and follow the activation process set out by the carrier.
