I noted the 8.0.2s027 firmware version. What is the difference with 8.02? I cannot find any additional info/release notes on this.
Hi Niek,
I can’t tell you what is specific about 8.0.1s027, but the “s” in the firmware version usually stands for a special build firmware.
If you have afeature request, Peplink will often create a special build firmware with this feature added.
For example 8.0.2s033 had Firewall and Region/SaaS added.
These features and fixes are then incorporated in the next general available firmware version.
