I’m debugging an issue, so doing packet captures on a local ethernet link from one of my Peplink Routers (B One), and I’m seeing what looks like something trying a traceroute I’m not expecting.
There are packets which appear to originate at the router to Google’s DNS (8.8.8.8 port 443), but with TTL values of 2 and 3. (Only 2 and 3.) Which then get ICMP time expired responses.
This is over the VLAN WAN to another unit (a B20X).
12:47:15.397152 d4:xx:xx:xx:xx:60 > 10:xx:xx:xx:xx:e0, ethertype 802.1Q (0x8100), length 78: vlan 7, p 0, ethertype IPv4 (0x0800), (tos 0x0, ttl 3, id 48276, offset 0, flags [none], proto TCP (6), length 60)
10.xx.xx.252.3111 > 8.8.8.8.443: Flags [S], cksum 0x6e7a (correct), seq 2020789940, win 5840, options [mss 1460,sackOK,TS val 2528426472 ecr 0,nop,wscale 2], length 0
12:47:15.467053 10:xx:xx:xx:xx:e0 > d4:xx:xx:xx:xx:60, ethertype 802.1Q (0x8100), length 74: vlan 7, p 0, ethertype IPv4 (0x0800), (tos 0x30, ttl 253, id 48276, offset 0, flags [none], proto ICMP (1), length 56)
10.5.102.254 > 10.xx.xx.252: ICMP time exceeded in-transit, length 36
(tos 0x30, ttl 1, id 48276, offset 0, flags [none], proto TCP (6), length 60)
10.xx.xx.252.3111 > 8.8.8.8.443: [|tcp]
The address 10.5.102.254 is not one I use on my network.
Any ideas?
