I’ve setup an Outbound rule to direct WebEx over the Smoothed tunnel, currently narrowed to my particular work laptop IP.
However, the data still appears to route over the other tunnel.
Any thoughts?
Any thoughts?
I think that deep packet inspection type rule only works if you are using the send all feature pictured here…
Set the destination to “any”
Source, destination and protocols are AND conditions. In your config you try to enforce routing of Webex application from 10.0.10.11 already sent towards SFC which is obviously not the case as the destination is Webex servers.
