I have seen some similar requested or assistants in regarding setting a web proxy for a specific wan only.
This is my current configuration - pepwave MAX
Inbound
- WAN (connected to enterprise network which has a non-transparent & user authentication proxy server/content filter)
- Cellular 1
- Cellular 2
These connections need to be able to be bounded.
Outbound
- multiple devices able to connect via Lan or Wi-fi to the internet without any user authentication needed or proxy settings in.
The reason of this is, we need a critical failover solution but when user devices have manually set the proxy setting on each device, and if the Wan fails, the devices will not be able to connect to the internet on the cellular’s as it looking for proxy server outside the enterprise network .
If we can at lease be able to set a proxy server settings on the pepwave max and the devices still needs to user authenticate on each device, I’m sure I could still make this work.
Can someone please explain and help me setup how I can set a proxy only on the WAN connection.
Thank You
