I am using a pepwave max HD2 for doing VPN site to site connection. The VPN works good.
The problem i have concern the WAN web admin access, in System–>admin security–> i proceeded as follow:[TABLE=“class: form_table, width: 1”]
CLI SSH
Enable
CLI SSH Port
Default
[TR=“class: mgt_port_only”]
CLI SSH Access
LAN Only LAN/WAN
[/TR]
Security
HTTP HTTPS HTTP / HTTPS
Web Admin Port
Default
[TR=“class: mgt_port_only hub_phylan_only”]
Web Admin Access
LAN Only LAN/WAN
[/TR]
[/TABLE]
However the connection to the admin interface still doesnt work through the WAN.
it seems like all what i configure are not taken into account although modifications are saved and then applied in the pepwave.
I have another pepwave used for VPN site to site which works very well with wan admin access.
Hello Jarid,
As i am in a vpn tunnel i try to access the device remotly using the LAN IP. The lan Ip is also pinged remotly without any problem.
I dont know the public ip wan, because the device is connected through the wan WIFI with a captif portail.
My vpn tunnel is built with dynamic IP from this side.
Do you thing a firewall located in the middle could bloque my http admin connection?
Thank you
Roukoz
It’s already set as allow for **Internal Network Firewall Rules **and remote LAN IP is routed into correct path. Ping is OK.
But i still don’t have admin access remotly
Any other idea please ?
