An IPsec VPN has been set up between my LAN (behind an ASA) and a remote LAN (behind a Peplink 30). Admin Access has been set to LAN/WAN. Pings to the Private IP of the Peplink are successful, but Admin Access is not available from my LAN using either the Public or Private IP of the Peplink.
Admin Access does work from outside the LAN using the Public IP of the Peplink. For security, would like to administer the Peplink through the VPN using the Private IP. Is that possible?
It could be the router in front of the ASA that blocking https traffic. Do you have access list that blocking? Are you able to access any https site from your LAN?
It sounds to me that everything is set up alright. Let’s submit a support ticket on http://www.peplink.com/contact/support/? Because I believe we will need a diagnostic report to look closer.
Got it. To speed things up could you please send in a diagnostic report after a few attempts to connect on private IP through the IPSec tunnel? I believe we will need it along the way so might as well do it now.
As requested, a Diagnostic Report has been submitted after a couple of connection attempts. The only option I could see was to create a new ticket, so it was submitted as #729801.
