Remote AP One can not establish WDS connection with AP One (base).
Squeme is as follows: SD-switch connected to ADSL (DHCP Server 192.168.1.254) on port 24. Port 1 connected AP One Enterprise (base). Clients connecting to AP getting access to Internet correctly.
When configuring WDS between AP Base and AP Remote, WDS is not fully established. Base side does not identify any Signal while remote AP signals -1db. Under this arrangement WDS connection is not established between APs. MAC addresses, SSID and Channels are correct on both AP. Any suggestion?
Base AP:
Remote AP:
LAN Switch
