This non-IT trained amateur has not kept up with the evolution of WDS technology or Mesh solutions where wiring just isn’t an option. So I ask the forum:
Is WDS a good idea? If not what other options are available? I thought that Surf SOHO as a router and base AP would be a great solution, but alas it doesn’t have WDS.
Brad
WDS is not available in Surf SOHO router. For more info, you may refer to the user manual here.
