I have a BR1 with two WAN Connections, a relatively slow Satellite link and a much faster Cellular link to the internet. I now wonder what the best SpeedFusion configuration would be for a good overall connection that i can use for video calls and also to surf the web and work with remote files from my fileserver at the office etc.
I saw a video on youtube explaining the setup of WAN Smoothing but they selected a different priority for each link which does not seem to make sense. When i do that on my BR1 (i.e. set Prio1 for Cellular data and prio2 for SAT data) i see no traffic going across the SAT link and the Staistics show no redundant Wan smoothing packets (blue triangles). As soon as I set both the SAT and Cellular link to prio1 i see blue triangles appear and i have traffic on both interfaces.
so did I understand correctly, that the video is wrong and I need to choose at least two interfaces with the same prio in order to enable WAN Smoothing?
sadly i have some other users on my network, so speed tests are a bit unreliable at the moment, but it seems that the overall speed with WAN Smoothing enabled is closer to the raw Cellular link speed than the much slower Satellite link speed. Do i Assume correctly, that with WAN smoothing over my two links i get more or less the speed and latency of the faster of the two links at any given time?
with wan smoothing enabled, does it make a difference what “Link Failure Detection Time” i configure in the PepVPN Settings?
so bottom line: in my situation with these two very different links WAN Smoothing across with both links set to prio1 is the best solution, right?
and now the extra question: would I profit from buying a bigger Peplink router that allows WAN Bonding or would that not add much speed and reliablity because of the extreme dfiferences in both latency and bandwith between my two connections?
kind regards
Chrsitian
