WAN on VLAN on Peplink SDX/SDX Pro
It would be great to be able to configure WAN on VLAN for the SDX/SDX Pro. It makes it much easier to get a WAN (often the secondary WAN) connected to two devices (ie Peplink’s in HA or a peplink & firewall).
I’m already doing this by adding a VLAN that only exists on the SD switch and connecting the WAN to it and manipulating the tagged/untagged settings on the ports. I use it with devices like the Balance 20X to interleave additional WAN’s using the new WAN over VLAN feature.
So I think the switch does what you need, it’s just not obvious how to set it up.
Sounds great, would you mind adding some screenshots?
Has there been any thought given to adding this yet?
It has this feature now. You will need to purchase vWAN licenses according to the number of needed WAN-over-VLAN interfaces needed.
